Ga door naar hoofdinhoud
How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse
Wat je nodig hebt
  1. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse, How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 1, afbeelding 1 van 1
    • Locate the three screw holes on the bottom of the mouse.
    • Two holes are under the top surface pads and one under the label sticker.
  2. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 2, afbeelding 1 van 3 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 2, afbeelding 2 van 3 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 2, afbeelding 3 van 3
    • Remove the top two surface pads on the bottom of your mouse using a flathead screwdriver.
    • Remove all three of the 5 mm Phillips #0 screws from the bottom cover.
    • The central screw is covered by a sticker, so you will need to poke a hole through the sticker to remove it.
  3. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 3, afbeelding 1 van 2 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 3, afbeelding 2 van 2
    • Gently lift up the top cover of the mouse to reveal the internal components.
    • Use a q-tip to clean any dirt/dust around the scroll wheel.
  4. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 4, afbeelding 1 van 2 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 4, afbeelding 2 van 2
    • Remove three 5 mm Phillips #0 screws and two 3 mm Phillips #0 screws located around the edges of the motherboard.
    • Lift the motherboard out from the case.
  5. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 5, afbeelding 1 van 2 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 5, afbeelding 2 van 2
    • Gently pull the scroll wheel to the right to disconnect it from the motherboard.
    • Clean any excess dirt that is stuck on both the scroll wheel and the motherboard.
    • When cleaning the motherboard, be sure to either use a dry cloth or isopropyl alcohol, as water will damage the circuitry.
  6. How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 6, afbeelding 1 van 2 How to Fix a Jammed Scroll Wheel for a Logitech G203 Prodigy Mouse: stap 6, afbeelding 2 van 2
    • Once you believe you are finished cleaning, reinstall and spin the scroll wheel to check if it works.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Keeran Ravishankar
353 Reputatie
1 Handleiding geschreven
8 opmerkingen
To anyone reading this, don’t bother just replace the mouse. If you remove the sticker thingies from the bottom of the plastic the mouse loses accuracy. I cleaned out the scroll wheel and the motherboard with isopropyl alcohol and it still wouldn’t turn properly, so I think my scroll wheel was defective. Looks like its time to get a new mouse.
Collin Schreur - Antwoord
Don't try using a commerical isopropyl alcohol cause that stuff would kills electronics and such. Though it's safe to use to clean it but it takes a while to let the board dry. PCB's and alcohol doesn't work nicely together so let it dry or use some kind of hair dryer (I kinda found this on accident by just watching a video on Odd Tinkering) if it feels the liquid is gone.
If you're talking about it loses mouse accuracy then maybe the mouse wasn't screwed in properly so there's some parts that are loosed screw around inside so take a time if it feels the screw is snug nicely. Clean the mouse inside? Maybe check Logitech G Hub or your DPI? Restart your computer?
There's also spare parts for Logitech G203 (G102 & G 305) mouse wheel replacements that sells it so google about that :)
If the mouse wheel wears out, maybe it's the time to replace the part
that's all i have
Nicholin V -
If it loses mouse accuracy, try cleaning it. Maybe there's some pet hairs or a dust that can get stuck in the lens and it's very hard to get a precision tracking if the device is dirty. But when you reassemble it make sure the screws that you've put in are right screw before they are in right place or else it wouldn't close in that way. It comes with different shapes and sizes. If that wasn't a problem either maybe clean your mousepad or any clean surface any that is free of dirt and dust. that's all :)
Nicholin V -
will this work on the g pro hero?
Thorin Ong - Antwoord
STEP 1 and 2
You definitely don't need to remove the rubber feets cause the screws are a bit small and very easy to lose them if not careful. So to pry it open halfway and unscrew it and the other rubber feet too. This should remove the housing.
Also the bottom hole where it's hidden on the sticker, you should also put a tape on it. So the other screw won't loose either. In other cases if you want to mod it.
There's also a hook at the bottom ; next close to the RGB lights where it should close properly when put reassembled.
In the aftermarket, just found out that logitech m275 mouse wheel roller works as a replacement if there's no actual spare part that sells the same
Nicholin V - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 27
Afgelopen 7 dagen: 163
Afgelopen 30 dagen: 690
Altijd: 29,427
