Ga door naar hoofdinhoud
How to Fix a Hole in a Pant Pocket
Wat je nodig hebt
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: stap 1, afbeelding 1 van 2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: stap 1, afbeelding 2 van 2
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: stap 2, afbeelding 1 van 2 How to Fix a Hole in a Pant Pocket: stap 2, afbeelding 2 van 2
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: stap 3, afbeelding 1 van 3 How to Fix a Hole in a Pant Pocket: stap 3, afbeelding 2 van 3 How to Fix a Hole in a Pant Pocket: stap 3, afbeelding 3 van 3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: stap 5, afbeelding 1 van 3 How to Fix a Hole in a Pant Pocket: stap 5, afbeelding 2 van 3 How to Fix a Hole in a Pant Pocket: stap 5, afbeelding 3 van 3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: stap 6, afbeelding 1 van 2 How to Fix a Hole in a Pant Pocket: stap 6, afbeelding 2 van 2
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: stap 7, afbeelding 1 van 1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dolapo Ajose
244 Reputatie
1 Handleiding geschreven
Één opmerking
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 57
Altijd: 4,776
