Ga door naar hoofdinhoud
How to Fix a Flexi Leash
Wat je nodig hebt
Video overzicht
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: stap 1, afbeelding 1 van 1
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: stap 2, afbeelding 1 van 3 How to Fix a Flexi Leash: stap 2, afbeelding 2 van 3 How to Fix a Flexi Leash: stap 2, afbeelding 3 van 3
    • Start by removing all the 0.5 cm screws off the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: stap 3, afbeelding 1 van 3 How to Fix a Flexi Leash: stap 3, afbeelding 2 van 3 How to Fix a Flexi Leash: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: stap 4, afbeelding 1 van 2 How to Fix a Flexi Leash: stap 4, afbeelding 2 van 2
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: stap 5, afbeelding 1 van 3 How to Fix a Flexi Leash: stap 5, afbeelding 2 van 3 How to Fix a Flexi Leash: stap 5, afbeelding 3 van 3
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: stap 6, afbeelding 1 van 3 How to Fix a Flexi Leash: stap 6, afbeelding 2 van 3 How to Fix a Flexi Leash: stap 6, afbeelding 3 van 3
    • Finish by screwing the 0.5 cm screws in their original position.
Eindstreep
Één opmerking
Where do i buy the spring?
Andrew Storeck - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 107
Altijd: 3,932
