Ga door naar hoofdinhoud
How to Fix a Dress Strap With a Clasp
Wat je nodig hebt
  1. How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: stap 1, afbeelding 1 van 3 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: stap 1, afbeelding 2 van 3 How to Fix a Dress Strap With a Clasp, How to Fix a Dress Strap With a Clasp: stap 1, afbeelding 3 van 3
    • Pull the end of the strap through the loop on the collar of the dress.
    • Locate the buckle along the length of the strap and feed the end of the strap under the opening of the buckle (closest to the strap).
    • Continue feeding the strap through the next opening of the buckle.
    Vraag FixBot
    Voeg opmerking toe
  2. How to Fix a Dress Strap With a Clasp: stap 2, afbeelding 1 van 3 How to Fix a Dress Strap With a Clasp: stap 2, afbeelding 2 van 3 How to Fix a Dress Strap With a Clasp: stap 2, afbeelding 3 van 3
    • Roll the end of the strap 1/8".
    • Roll it one more time.
    • Compare the newly made loop to the other functioning strap to ensure the loops are the same length.
    Vraag FixBot
    Voeg opmerking toe
  3. How to Fix a Dress Strap With a Clasp: stap 3, afbeelding 1 van 1
    • Secure the fold with the needle and thread.
    • Never use any part of your hand to brace the material as you push the needle through it, to avoid minor injuries.
    • For instructions on how to thread a needle, follow this tutorial: How to thread a needle.
    Vraag FixBot
    Voeg opmerking toe
  4. How to Fix a Dress Strap With a Clasp: stap 4, afbeelding 1 van 2 How to Fix a Dress Strap With a Clasp: stap 4, afbeelding 2 van 2
    • Poke the needle through to one edge of the looped strap to begin securing the fold to the strap.
    • Begin sewing along the width of the strap, using a short stitch length (2.0 mm).
    Vraag FixBot
    Voeg opmerking toe
  5. How to Fix a Dress Strap With a Clasp: stap 5, afbeelding 1 van 3 How to Fix a Dress Strap With a Clasp: stap 5, afbeelding 2 van 3 How to Fix a Dress Strap With a Clasp: stap 5, afbeelding 3 van 3
    • To finish securing the fabric together, create a loop with the excess thread attached to the needle.
    • Use a quilter's knot to finish securing the fabric.
    • For more detail on performing a quilters knot, follow this link: Quilters Knot.
    Vraag FixBot
    Voeg opmerking toe
  6. How to Fix a Dress Strap With a Clasp: stap 6, afbeelding 1 van 2 How to Fix a Dress Strap With a Clasp: stap 6, afbeelding 2 van 2
    • Pull the knot tightly.
    • Cut the excess thread with the scissors.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Luke Bartels
133 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 166
Altijd: 188
