Inleiding
With frequent daily uses, mouses can become dirty. A lag can occur between the mouse movements and what is displayed on the monitor screen. This is typically caused by a device inside the mouse call the optical sensor. The optical sensor gets dirty with frequent use and causes lag. Luckily, it’s very easy to fix! This guide will walk you through how to clean the optical sensor to reduce lagging, step-by-step. This fast-fix should take 10 minutes maximum. The tools needed include:
- Phillips head screwdriver
- Q-tips or a soft cloth
- 90% Isopropyl alcohol
Wat je nodig hebt
Start by flipping the mouse over to view the flat side of the mouse.
Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
why did you opened it if you just cleaned eye with alcohol
