Ga door naar hoofdinhoud
How to Fix a Dirty Censor in a Corsair Harpoon RGB
Wat je nodig hebt
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 1, afbeelding 1 van 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 1, afbeelding 2 van 2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 2, afbeelding 1 van 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 2, afbeelding 2 van 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 2, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 3, afbeelding 1 van 1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 4, afbeelding 1 van 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 4, afbeelding 2 van 2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 5, afbeelding 1 van 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: stap 5, afbeelding 2 van 2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Conclusie
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Antwoord
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 179
Altijd: 6,141
