Ga door naar hoofdinhoud
How to Fix a Delta 5-Function Showerhead Model 75554
Wat je nodig hebt
  1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: stap 1, afbeelding 1 van 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: stap 1, afbeelding 2 van 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: stap 1, afbeelding 3 van 3
    • Unscrew the head of the shower from the pipe with a pipe wrench.
    • While using the pipe wrench, make sure not to clamp it too tight because it will crack the plastic.
  2. How to Fix a Delta 5-Function Showerhead Model 75554: stap 2, afbeelding 1 van 2 How to Fix a Delta 5-Function Showerhead Model 75554: stap 2, afbeelding 2 van 2
    • Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
  3. How to Fix a Delta 5-Function Showerhead Model 75554: stap 3, afbeelding 1 van 2 How to Fix a Delta 5-Function Showerhead Model 75554: stap 3, afbeelding 2 van 2
    • With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
    • Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
    • Pocketknives can be very very sharp!
  4. How to Fix a Delta 5-Function Showerhead Model 75554: stap 4, afbeelding 1 van 2 How to Fix a Delta 5-Function Showerhead Model 75554: stap 4, afbeelding 2 van 2
    • Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
  5. How to Fix a Delta 5-Function Showerhead Model 75554: stap 5, afbeelding 1 van 2 How to Fix a Delta 5-Function Showerhead Model 75554: stap 5, afbeelding 2 van 2
    • Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
    • Now is the time to take the shower head out of the vinegar water.
  6. How to Fix a Delta 5-Function Showerhead Model 75554: stap 6, afbeelding 1 van 3 How to Fix a Delta 5-Function Showerhead Model 75554: stap 6, afbeelding 2 van 3 How to Fix a Delta 5-Function Showerhead Model 75554: stap 6, afbeelding 3 van 3
    • Twist the shower head back onto the pipe and tighten it with the pipe wrench.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Faith Henson
160 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,516
