Ga door naar hoofdinhoud
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
Wat je nodig hebt
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 1, afbeelding 1 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 1, afbeelding 2 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 1, afbeelding 3 van 3
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 2, afbeelding 1 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 2, afbeelding 2 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 2, afbeelding 3 van 3
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 3, afbeelding 1 van 1
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 4, afbeelding 1 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 4, afbeelding 2 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 4, afbeelding 3 van 3
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 5, afbeelding 1 van 1
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 6, afbeelding 1 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 6, afbeelding 2 van 3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 6, afbeelding 3 van 3
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 7, afbeelding 1 van 1
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: stap 8, afbeelding 1 van 1
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
Conclusie
Sydney Schuett
211 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G14, Cardinal Summer 2020 Lid van UW Tacoma, Team S1-G14, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G14
1 Lid
1 handleiding geschreven
Één opmerking
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 70
Altijd: 2,626
