Inleiding
If your Lady Zest Q Nasal CPAP Mask with Headgear is cracked and leaking air use this guide to repair the crack in the mask. The mask is used to to provide a seal around your nose so that positive pressure can maintained when you breathe. Before you begin this guide you will check the mask for where the crack is located and how big it is. Be sure to wear latex gloves that can be disposed of while working with the resin, as it is very sticky and once dried will be harder to remove safely.
Wat je nodig hebt
Trim the edges of the fiberglass sheet into small strips that cover the crack on the mask.
