Ga door naar hoofdinhoud
How to Fix a Crack in a Hollow Wood Door
Wat je nodig hebt
  1. How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: stap 1, afbeelding 1 van 2 How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: stap 1, afbeelding 2 van 2
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. How to Fix a Crack in a Hollow Wood Door: stap 2, afbeelding 1 van 1
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. How to Fix a Crack in a Hollow Wood Door: stap 3, afbeelding 1 van 1
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. How to Fix a Crack in a Hollow Wood Door: stap 4, afbeelding 1 van 1
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  5. How to Fix a Crack in a Hollow Wood Door: stap 5, afbeelding 1 van 1
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  6. How to Fix a Crack in a Hollow Wood Door: stap 6, afbeelding 1 van 1
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  7. How to Fix a Crack in a Hollow Wood Door: stap 7, afbeelding 1 van 2 How to Fix a Crack in a Hollow Wood Door: stap 7, afbeelding 2 van 2
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  8. How to Fix a Crack in a Hollow Wood Door: stap 8, afbeelding 1 van 1
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  9. How to Fix a Crack in a Hollow Wood Door: stap 9, afbeelding 1 van 1
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Lea Thomas
250 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 460
Altijd: 150,625
