Ga door naar hoofdinhoud
How to Fix a Chair Armrest
Wat je nodig hebt
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: stap 1, afbeelding 1 van 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: stap 1, afbeelding 2 van 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: stap 1, afbeelding 3 van 3
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: stap 2, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 2, afbeelding 2 van 2
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: stap 3, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 3, afbeelding 2 van 2
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: stap 4, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 4, afbeelding 2 van 2
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: stap 5, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 5, afbeelding 2 van 2
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: stap 6, afbeelding 1 van 3 How to Fix a Chair Armrest: stap 6, afbeelding 2 van 3 How to Fix a Chair Armrest: stap 6, afbeelding 3 van 3
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: stap 7, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 7, afbeelding 2 van 2
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: stap 8, afbeelding 1 van 3 How to Fix a Chair Armrest: stap 8, afbeelding 2 van 3 How to Fix a Chair Armrest: stap 8, afbeelding 3 van 3
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: stap 9, afbeelding 1 van 2 How to Fix a Chair Armrest: stap 9, afbeelding 2 van 2
    • All done! Now your armrest should feel securely attached to the chair.
Conclusie
These are moderate step to fix your chair armrest.
Één andere persoon heeft deze handleiding voltooid.
Deviny
196 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 51
Altijd: 2,483
