Ga door naar hoofdinhoud
How to Fix a Brazilian Hammock
Wat je nodig hebt
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: stap 1, afbeelding 1 van 1
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: stap 2, afbeelding 1 van 2 How to Fix a Brazilian Hammock: stap 2, afbeelding 2 van 2
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: stap 3, afbeelding 1 van 1
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: stap 4, afbeelding 1 van 1
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: stap 5, afbeelding 1 van 3 How to Fix a Brazilian Hammock: stap 5, afbeelding 2 van 3 How to Fix a Brazilian Hammock: stap 5, afbeelding 3 van 3
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: stap 6, afbeelding 1 van 3 How to Fix a Brazilian Hammock: stap 6, afbeelding 2 van 3 How to Fix a Brazilian Hammock: stap 6, afbeelding 3 van 3
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: stap 7, afbeelding 1 van 1
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: stap 8, afbeelding 1 van 2 How to Fix a Brazilian Hammock: stap 8, afbeelding 2 van 2
    • Remove all the safety pins and appreciate your work.
Conclusie
This guide is now completed, enjoy your newly restored hammock.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 39
Altijd: 99
