Ga door naar hoofdinhoud
How to Fix a BIC Wite-Out Mini
Wat je nodig hebt
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: stap 1, afbeelding 1 van 1
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
  2. How to Fix a BIC Wite-Out Mini: stap 2, afbeelding 1 van 1
    • Stabilize the small gear with tweezers to prevent further unwinding.
  3. How to Fix a BIC Wite-Out Mini: stap 3, afbeelding 1 van 3 How to Fix a BIC Wite-Out Mini: stap 3, afbeelding 2 van 3 How to Fix a BIC Wite-Out Mini: stap 3, afbeelding 3 van 3
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
  4. How to Fix a BIC Wite-Out Mini: stap 4, afbeelding 1 van 3 How to Fix a BIC Wite-Out Mini: stap 4, afbeelding 2 van 3 How to Fix a BIC Wite-Out Mini: stap 4, afbeelding 3 van 3
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
  5. How to Fix a BIC Wite-Out Mini: stap 5, afbeelding 1 van 1
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
  6. How to Fix a BIC Wite-Out Mini: stap 6, afbeelding 1 van 1
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
  7. How to Fix a BIC Wite-Out Mini: stap 7, afbeelding 1 van 3 How to Fix a BIC Wite-Out Mini: stap 7, afbeelding 2 van 3 How to Fix a BIC Wite-Out Mini: stap 7, afbeelding 3 van 3
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
  8. How to Fix a BIC Wite-Out Mini: stap 8, afbeelding 1 van 2 How to Fix a BIC Wite-Out Mini: stap 8, afbeelding 2 van 2
    • Close the device until the side components click closed.
Conclusie
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
Lauren Miller
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-1, Andersen Winter 2024 Lid van UC Davis, Team 3-1, Andersen Winter 2024
UCD-ANDERSEN-W24S3G1
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 138
