Ga door naar hoofdinhoud
How to Fix Xbox 360 Controller Joystick Drift
Wat je nodig hebt
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: stap 1, afbeelding 1 van 2 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: stap 1, afbeelding 2 van 2
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: stap 2, afbeelding 1 van 2 How to Fix Xbox 360 Controller Joystick Drift: stap 2, afbeelding 2 van 2
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: stap 3, afbeelding 1 van 2 How to Fix Xbox 360 Controller Joystick Drift: stap 3, afbeelding 2 van 2
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: stap 4, afbeelding 1 van 2 How to Fix Xbox 360 Controller Joystick Drift: stap 4, afbeelding 2 van 2
    • Use a blow dryer to dry both the left and right joysticks.
Conclusie
Luis Ramirez
162 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 9-6, Briggs Fall 2022 Lid van CSU Los Angeles, Team 9-6, Briggs Fall 2022
CSULA-BRIGGS-F22S9G6
1 Lid
5 handleidingen geschreven
2 opmerkingen
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - Antwoord
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 242
Afgelopen 30 dagen: 1,127
Altijd: 17,608
