Ga door naar hoofdinhoud
How to Fix Stuck Yamaha PSR-6 Keyboard Keys
Wat je nodig hebt
  1. How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 1, afbeelding 1 van 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 1, afbeelding 2 van 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 1, afbeelding 3 van 3
    • Turn around the keyboard with the keys facing down.
    • Remove the 15 10 mm screws using a Phillips #1 screwdriver.
    • Remove the five 12 mm screws using a Phillips #1 screwdriver.
    • Remove the extra two 10 mm screws in the bottom using a Phillips #1 screwdriver.
  2. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 2, afbeelding 1 van 1
    • Pull the tab and remove the battery cover.
  3. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 3, afbeelding 1 van 1
    • Take the back plate of the piano with both hands and remove it.
  4. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 4, afbeelding 1 van 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 4, afbeelding 2 van 2
    • Turn around the piano with the tiles facing up.
    • Remove the speaker's cover on the left side of the keyboard.
    • Remove the plastic cover on the right side of the keyboard.
  5. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 5, afbeelding 1 van 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 5, afbeelding 2 van 2
    • Flip the keyboard with the keys facing down.
    • Remove the single 12 mm screw using a Phillips #1 screwdriver.
  6. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 6, afbeelding 1 van 1
    • Lift the front plate of the keyboard and rotate it 180°.
    • While doing this, grab the speaker with the other hand so it doesn't fall and hit the table.
  7. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 7, afbeelding 1 van 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 7, afbeelding 2 van 2
    • Remove all the 10 mm screws on the top of the keys using a Phillips #1 screwdriver.
  8. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 8, afbeelding 1 van 1
    • Use a spudger to separate the teeth to the plates that hold the keys together.
    • Do this gently as the plate may be fragile.
  9. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: stap 9, afbeelding 1 van 1
    • Pull the black plate that holds the keys together horizontally away from the keys.
    • With the top of the keys exposed, use a damp cloth or wipes to clean the space between the tiles.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 70
Altijd: 1,634
