Ga door naar hoofdinhoud
How to Fix Ripped Jeans Hem Without Shortening
Wat je nodig hebt
  1. How to Fix Ripped Jeans Hem Without Shortening, How to Fix Ripped Jeans Hem Without Shortening: stap 1, afbeelding 1 van 2 How to Fix Ripped Jeans Hem Without Shortening, How to Fix Ripped Jeans Hem Without Shortening: stap 1, afbeelding 2 van 2
    • Cut away loose threads from the bottom of each pant leg with scissors.
  2. How to Fix Ripped Jeans Hem Without Shortening: stap 2, afbeelding 1 van 1
    • Use a tape measure/ruler to measure the length of the worn area.
    • Mark the measurements across the fabric with a pen/pencil.
  3. How to Fix Ripped Jeans Hem Without Shortening: stap 3, afbeelding 1 van 2 How to Fix Ripped Jeans Hem Without Shortening: stap 3, afbeelding 2 van 2
    • Use scissors to trim along the marked line, creating a straight hem.
  4. How to Fix Ripped Jeans Hem Without Shortening: stap 4, afbeelding 1 van 1
    • Turn the jeans inside out.
  5. How to Fix Ripped Jeans Hem Without Shortening: stap 5, afbeelding 1 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 5, afbeelding 2 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 5, afbeelding 3 van 3
    • Fold the bottom of the jeans up to create a cuff.
    • Poke the needle through the jean.
    • Bring the needle back up at a second point to pin it in place.
  6. How to Fix Ripped Jeans Hem Without Shortening: stap 6, afbeelding 1 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 6, afbeelding 2 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 6, afbeelding 3 van 3
    • Cut a piece of thread twice the length of the jean cuff.
    • Insert the thread through the needle’s eye.
    • Tie a knot at the ends of the thread to secure it.
  7. How to Fix Ripped Jeans Hem Without Shortening: stap 7, afbeelding 1 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 7, afbeelding 2 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 7, afbeelding 3 van 3
    • Insert the needle from underneath the folded hem.
    • Pull the needle through the fabric to the top.
    • Move the needle half of a centimeter to the right and pull the needle through the fabric to the bottom.
    • Repeat this along the hem to create even stitches.
  8. How to Fix Ripped Jeans Hem Without Shortening: stap 8, afbeelding 1 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 8, afbeelding 2 van 3 How to Fix Ripped Jeans Hem Without Shortening: stap 8, afbeelding 3 van 3
    • Insert the needle near the last stitch.
    • Pull the thread partially to make a loop.
    • Pass the needle through the loop and pull tight to secure the knot.
    • Repeat twice for extra strength.
  9. How to Fix Ripped Jeans Hem Without Shortening: stap 9, afbeelding 1 van 1
    • Cut any excess thread with scissors.
  10. How to Fix Ripped Jeans Hem Without Shortening: stap 10, afbeelding 1 van 1
    • Turn the jeans inside out again.
    • Repeat the same process on the other leg.
Eindstreep
Apple Lin
181 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-5, Vidal-Chiesa Fall 2024 Lid van UC Davis, Team 2-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G5
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 39
Altijd: 138
