Ga door naar hoofdinhoud
How to Fix Plastic Chair Cracks
Wat je nodig hebt
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: stap 1, afbeelding 1 van 2 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: stap 1, afbeelding 2 van 2
    • Lay the broken chair such that the crack is parallel to the floor.
  2. How to Fix Plastic Chair Cracks: stap 2, afbeelding 1 van 2 How to Fix Plastic Chair Cracks: stap 2, afbeelding 2 van 2
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
  3. How to Fix Plastic Chair Cracks: stap 3, afbeelding 1 van 2 How to Fix Plastic Chair Cracks: stap 3, afbeelding 2 van 2
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
  4. How to Fix Plastic Chair Cracks: stap 4, afbeelding 1 van 3 How to Fix Plastic Chair Cracks: stap 4, afbeelding 2 van 3 How to Fix Plastic Chair Cracks: stap 4, afbeelding 3 van 3
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
  5. How to Fix Plastic Chair Cracks: stap 5, afbeelding 1 van 1
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
  6. How to Fix Plastic Chair Cracks: stap 6, afbeelding 1 van 3 How to Fix Plastic Chair Cracks: stap 6, afbeelding 2 van 3 How to Fix Plastic Chair Cracks: stap 6, afbeelding 3 van 3
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
  7. How to Fix Plastic Chair Cracks: stap 7, afbeelding 1 van 2 How to Fix Plastic Chair Cracks: stap 7, afbeelding 2 van 2
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
  8. How to Fix Plastic Chair Cracks: stap 8, afbeelding 1 van 3 How to Fix Plastic Chair Cracks: stap 8, afbeelding 2 van 3 How to Fix Plastic Chair Cracks: stap 8, afbeelding 3 van 3
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
  9. How to Fix Plastic Chair Cracks: stap 9, afbeelding 1 van 2 How to Fix Plastic Chair Cracks: stap 9, afbeelding 2 van 2
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
  10. How to Fix Plastic Chair Cracks: stap 10, afbeelding 1 van 2 How to Fix Plastic Chair Cracks: stap 10, afbeelding 2 van 2
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
  11. How to Fix Plastic Chair Cracks: stap 11, afbeelding 1 van 1
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
  12. How to Fix Plastic Chair Cracks: stap 12, afbeelding 1 van 1
    • The crack has been repaired!
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Sumeet Dhillon
295 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G7, Andersen Winter 2020 Lid van UC Davis, Team S2-G7, Andersen Winter 2020
UCD-ANDERSEN-W20S2G7
3 Leden
5 handleidingen geschreven
2 opmerkingen
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - Antwoord
What glue did you use?
Raffaele Bianchi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 187
Afgelopen 30 dagen: 908
Altijd: 42,741
