Ga door naar hoofdinhoud
How to Fix PS4 Controller Analog Drift (R3 or L3 not working)
Wat je nodig hebt
  1. How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 1, afbeelding 1 van 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 1, afbeelding 2 van 2
    • Remove the four screws from the back of your controller using a Phillips #0 screwdriver.
    • Separate the front and the back of the controller.
  2. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 2, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 2, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 2, afbeelding 3 van 3
    • Unplug the ribbon cable to disconnect the Micro-USB Type B port from the controller itself.
    • Be careful not to tear or damage the cable.
  3. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 3, afbeelding 1 van 1
    • Unplug the battery from the controller and take it out.
    • Be careful not to tear or damage the wire as this is an important component for your controller.
  4. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 4, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 4, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 4, afbeelding 3 van 3
    • Remove the single screw from the black plate covering the motherboard using a Phillips #0 screwdriver.
    • Remove the black plate from the controller.
  5. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 5, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 5, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cable that connects the back of the controller to the motherboard.
    • Remove the motherboard from the back of the controller.
    • Be careful not to tear or damage this wire as it is important for your controller.
  6. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 6, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 6, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 6, afbeelding 3 van 3
    • Remove the toggle sticks from the controller.
    • Be careful of the sensors as they are very sensitive.
  7. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 7, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 7, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 7, afbeelding 3 van 3
    • Use a spudger to pry open the toggle stick sensor.
    • Use a cotton swab with a little bit of rubbing alcohol to remove the grease and build-up from the sensor.
  8. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 8, afbeelding 1 van 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 8, afbeelding 2 van 2
    • To reassemble the controller, place the back cover onto the motherboard.
    • Slip the red wire through the controller cover and plug it in.
  9. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 9, afbeelding 1 van 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 9, afbeelding 2 van 2
    • Put the black plate back on top of the motherboard and screw it in.
    • Make sure the back of the controller and the motherboard are firmly connected.
  10. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 10, afbeelding 1 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 10, afbeelding 2 van 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 10, afbeelding 3 van 3
    • Plug the battery back in and put it in its place.
    • Plug the white wire back into the motherboard.
  11. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 11, afbeelding 1 van 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 11, afbeelding 2 van 2
    • Connect the front cover and the back cover of the controller and screw the four screws back in.
  12. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): stap 12, afbeelding 1 van 1
    • You're all done.
Eindstreep
43 andere personen hebben deze handleiding voltooid.
Sabih Akram
1.543 Reputatie
2 handleidingen geschreven
5 opmerkingen
Thank you for this!! So many great pictures!! :D
The drift for me also prevented or interrupted movement with the left analog stick. Menus would continue to scroll after i scrolled them or wouldn’t move my character on screen.
briandewitt - Antwoord
Nach Wechsel der Potis hatte mein Controller Drift an beiden Achsen. Das liegt daran, dass die Potis nicht 100% mit denen der Werkskalibrierten übereinstimmen. Eine nachträgliche Kalibrierung ist leider nicht so einfach möglich, da die Korrekturdaten im EEPROM des Controllers gespeichert sind. Deshalb habe ich parallel zu den Potis je einen 2MOhm Poti gelötet, mit denen der Spannungsoffset kompensiert werden kann. Ergebnis: Keine Drift mehr. Die Controller arbeiten wieder einwandfrei.
zapf2000 - Antwoord
Well organised pictorial lecture.great work.
Egeonu - Antwoord
Great walkthrough and high-res images makes the job a lot smoother. Only remark I have are three things: 1) There are four clips that are hard to see on the images, and aren’t detailed; they are on the top right and left, under the “SHARE” and “OPTIONS” buttons, as well as the two clips on either side of the docking port. These easily break, although I avoided that. 2) The sensor housing have very fragile clips which easily break after a repair or two. DO NOT USE FORCE ON THESE! If you’re in doubt, just try and blow some air into them. Some remaining dirt is better than a broken stick. I also avoided this thanks to a comment on the step, but I’ve heard many has broken their sensors doing this. 3) The USB connector isn’t labeled as a pull-out connector. This isn’t much of an issue, but in sub-par lit environments, it looks like a clip connector. Have some friends ruining their USB ports due to ripping the connector off the PCB, thinking it’s a clip connector.
Franz Rolfsvaag - Antwoord
tidak membantu sama sekali seperti padi yang terbanjiri dan tidak bisa di proses untuk menjadi nasi lalu di nikmati
Dzakwan Afiq - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 45
Afgelopen 7 dagen: 282
Afgelopen 30 dagen: 1,253
Altijd: 58,706
