Inleiding
If you have a Nintendo Switch, one problem that you likely have had to deal with is stick drift. If you don't know, stick drift is when your Joy-Con joysticks move on their own. Often you can't see it move, because it's such a slight movement, but the console receives this input. This problem becomes extremely frustrating in many games because you have to constantly correct the self-moving character or camera angle. I've become pretty fed up with it, so I made this guide to help others fix their Joy-Cons instead of spending $70 for a new set. It doesn't take very long. All you need is a bottle of 404B Contact Cleaner, a pair of tweezers, and 5-10 minutes of your time.
Wat je nodig hebt
Hold the button on the black button on the Joy-Con, and slide the controller off the console.
Lift the rubber grip and hold it with tweezers.
Aim the nozzle of the 404B Cleaner into the joystick gap, and spray it up to twice.
Rotate the joystick for 30-60 seconds to allow the cleaner to circulate.
If the problem is not solved, repeat steps 1-6, and then test the Joy-Con.
