Inleiding
Use this repair guide to fix any chipped wood furniture that may be ruining the aesthetic of your room.
For many, buying second-hand or vintage furniture has become the latest trend in trying to enjoy a more sustainable lifestyle. Wood furniture, especially, can be easily damaged over time. Therefore, knowing how to fix minor scratches or chips on them is an essential skill to possess.
Before using this guide, it is critical you choose the right wood stain that matches your furniture exactly. Additionally, it is equally vital to familiarize yourself with a cordless drill, in case you need to use one.
Make sure to be patient and wait for the wood filler to be completely dry before sanding. Otherwise, it causes the filler to be uneven and increases your repair time as you may need to restart the process.
Be sure to work in a well-ventilated area, free of clutter to avoid any accidents. It may also be productive to lay down a plastic sheet and perform the restoration on top. This ensures an easy cleanup and averts the possibility of getting wood stain on your floors.
Wat je nodig hebt
Clean the affected/damaged area of the wood and remove any dust or small wood particles using a clean brush or a paper towel.
While waiting for the wood filler to dry, you may choose to fix the other chips or scratches on the wood that do not require the use of wood filler.
Make sure to clean the smaller scratches and slightly sand them using the 150 grit sandpaper.
Then use a wood stain of your preferred shade that matches the rest of the wood and carefully fill in the affected areas
The repair guide can be used to fix any type of wooden furniture by making sure you choose the right wood stain. Happy Fixing!
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Thanks for sharing this informative article with us and i have seen more furniture repair here https://10minutesformom.com/home-improve...
