Ga door naar hoofdinhoud
How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns
Wat je nodig hebt
    1. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns, Replacing Ram Sticks and Adding A New SSD: stap 1, afbeelding 1 van 1
      • The ASUS Prime Z790-P motherboard manual shows that there is another M.2 socket available.
      • There is also only one RAM stick slotted in, so we will be adding more.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 2, afbeelding 1 van 2 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 2, afbeelding 2 van 2
      • Remove the Singular RAM stick that is slotted in.
      • The older RAM Stick is the same as the two being added in, so to avoid wasting technology that still works, we will add it back in with the two new RAM sticks.
      • Running three RAM sticks can slow your device instead of assisting it. We are doing it because the ASUS PRIME Z790-P motherboard manual allows it.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 3, afbeelding 1 van 2 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 3, afbeelding 2 van 2
      • Place the RAM Sticks into their slots.
      • Warning: The RAM sticks might give a little pushback when entering the slot, but make sure not to place too much force, or else the contact pins can snap.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 4, afbeelding 1 van 3 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 4, afbeelding 2 van 3 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 4, afbeelding 3 van 3
      • Now, we will use our tools to insert the new SSD into the available slot. The tools we need are the magnetic screwdriver, one M2 mounting screw, and one M2 screw.
      • There are empty slots, as circled in the second photo; place an M2 mounting screw into the slot.
      • After that, place the SSD into its slot and align the head to the mounting screw. Properly screw the SSD into place.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 5, afbeelding 1 van 3 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 5, afbeelding 2 van 3 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 5, afbeelding 3 van 3
      • Reseal the PC with the glass and place the PC upright once more.
      • Turn on the PC once more. If your PC boots into Windows, then this was a success! If the PC does not boot into Windows, then go back to step 3 and check your RAM sticks.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 6, afbeelding 1 van 2 How to Fix ASUS PRIME Z790-P Motherboard Crashes and Slowdowns: stap 6, afbeelding 2 van 2
      • Since we added a new SSD, we must go to Device Manager to initialize the device. Search for Device Manager on your PC and open the application.
      • After arriving at Device Manager, you will see an unallocated disk. Name the disk to initialize it; in this instance, SSD (P:) is our new disk.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
After following this guide, your PC should be fully functional again, and it should no longer experience crashes and slowdowns. It is important not to waste functional technology, which is why we kept the RAM stick in the PC. When upgrading your ASUS PRIME Z790-P motherboard, or any other motherboard, please reference your user manual to ensure the best outcome.
JG2025
187 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-60, Harris Spring 2025 Lid van CSU Los Angeles, Team 5-60, Harris Spring 2025
CSULA-HARRIS-S25S5G60
1 Lid
12 handleidingen geschreven
1Gids Commentaar
Hard disk not linking
Ali Khan Baloch - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 136
Altijd: 1,510
