Ga door naar hoofdinhoud
How to Fix A Warped Frisbee Disc
Wat je nodig hebt
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: stap 1, afbeelding 1 van 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: stap 1, afbeelding 2 van 2
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: stap 2, afbeelding 1 van 1
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: stap 3, afbeelding 1 van 1
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: stap 4, afbeelding 1 van 1
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: stap 5, afbeelding 1 van 1
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
Conclusie
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
Bryce Petersen
164 Reputatie
1 Handleiding geschreven
Cal Poly, Team 30-5, Green Spring 2015 Lid van Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Leden
31 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 102
Altijd: 9,595
