Inleiding
Wire leads are attached inside to heat the toaster oven. Use this guide to repair the heating mechanism to regain use of your toaster oven.
Onderdelen
Geen onderdelen nodig.
  1. If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
    • If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
      • When a broken lead is found, reattach by removing the screw at its original attachment point.
  2. Make sure that the lead is attached and in contact.
    • Make sure that the lead is attached and in contact.
    • Retighten screw to secure lead.
Conclusie
Tony Wang
64 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-35, Regan Fall 2012 Lid van Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 15
Altijd: 992
