Ga door naar hoofdinhoud
How to Factory / Hard Reset Nokia Lumia 520
Video overzicht
  1. How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: stap 1, afbeelding 1 van 3 How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: stap 1, afbeelding 2 van 3 How to Factory / Hard Reset Nokia Lumia 520, How to Factory / Hard Reset Nokia Lumia 520: stap 1, afbeelding 3 van 3
    • 1. Turn off the phone.
    • 2. Press and hold the Volume Down and Power On buttons.
    • 3. When you feel a vibration, release only the Power On button.
    • 4. You will see on the screen an exclamation mark (!).
    • 5. Press the keys in this order: • Volume Up > Volume Down > Power > Volume Down •
    • The phone will restart.
    • Did you do it successfully?
    Yes, yes,and yes
    kelvin arendse - Antwoord
    Didn’t work for me, I have the explanation mark, but as soon as I press the power button after vol up and dwn, it goes away and starts as usual.
    Simon Cusonnet - Antwoord
    then how did you do it?
    Arpanjot singh -
    I can see the exclamation symbol, but it shows only the exclamation symbol, no more
    Richyreaz - Antwoord
    it has worked sucessfully
    adams roland - Antwoord
    Worked well eventually. Note to self: read instructions CAREFULLY, but it worked after I read them properly!
    sue.edwards48 - Antwoord
    Yes it worked great. I did remove the sim and sd cards beforehand so as not to accidentally erase my saved data . Reinstalled them after startup and my phone is now back to functioning as I want it. Thanks for the hand.
    albert pruim - Antwoord
    Am going through the process well but once it reboots the blue screen with sad face re-appears
    robert gitende - Antwoord
    mine is asking for the protection recovery key
    coffi capello - Antwoord
    thanks its so helpful
    reason nhambura - Antwoord
    No,flight mode always on after hard resetting
    shavhani wa netshifhefhe - Antwoord
    Thanks very much.am sorted.Viva!
    Kipkemoi Kibiwott - Antwoord
    Super!!! Muchas gracias fue de mucha ayuda
    princesita696 - Antwoord
    Yes. Good. It worked very well. Thank you. Absolute result. Not even expected the process would be like this
    shiyaz khan - Antwoord
    Very Good Solution. Thank You.
    Lance Hildyard - Antwoord
    i did all the proccess but still its reserting its been a day now.please help
    mosime92 - Antwoord
    You guys are awesome. M making money out of this. Thank you so much for the hand.
    Brian Muuma - Antwoord
    excellent piece of advice worked like a dream
    kevin.pipefitter - Antwoord
    When mine vibrates and I hold down the volume down button it just restarts over and over again help plz
    Abs an a Am - Antwoord
    mine never worked it keeps restarting
    Caroline Darko - Antwoord
    my never worked and please is there anyway out that you can help me
    jedidiah - Antwoord
    flight mode remains on
    Gershom Bario - Antwoord
    Thanks. Worked perfectly.
    Tony Williams - Antwoord
    Thanks....works perfectly
    Dannie Chakholoma - Antwoord
Conclusie
This guide shows only how to erase the content of your phone.
62 andere personen hebben deze handleiding voltooid.
ZFix
191.308 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
24 opmerkingen
i have a challenge with my Lumia 520 i cant see the apps the screen is fine its difficult to format and everything in the phone is ok just that i cant use the phone its been given me issues and i have taken it for repairs they confirmed it needs to be flashed but i dont know what to flash it with as all the technicians i took it too couldn't flash the phone
godwing4 - Antwoord
Nokia Lumia 520 IMEI 358106054625804
Bawii Ali Sumail - Antwoord
Will this's reboot setting helps my Nokia 520 if the touch screen is lagging and i can only use my screen for certain things?
jessicaaa__014 - Antwoord
Hi my Nokia Lumia 520 is behaving weird lately,hanging most of the time ,touch not functioning well,.Recently it request me to do booting , what am i supposed to do?
Kizito. 28/5/2018
tobiaskizito -
What if my lumia 520 gets stuck on turning gears (reset mode)?
Sibusiso Dangazela - Antwoord
Gaand mein daal lena fir
catchprashantpandey -
hi Just to clear your doubt…Your nokia will never get stuck on the gears thing….maybe take a couple of hours…
Red hood Plays768 -
I have a password in my phone but the error is “try again in 164325 minutes“ so the only way is the hard reset, but my volume up were broken. What am i suppose to do? Is there any other way to fix this? Or I’ll just wait for that 123456 minutes to be over!?
Govan Cado - Antwoord
I'm having the same problem as yours. Have found ways to over come it. Please share. Thanks
saranjohl -
Successfully working
Kettie Sibanda - Antwoord
what if i can’t access other applications on my nokia 520? it can’t load application.
flshfit - Antwoord
my phone was switched off now when I switch it on its in airplane mode and it doesn't allow me to switch to 3G.
Mabu Molele - Antwoord
Comes ! exclamation sign but can't open?
Suranjan Chakravarty - Antwoord
It doesn't seem to be working for me but the phone is nearly dead and is on charge. Could that possibly be why?
Chi-Chi The Krazee Kat - Antwoord
after flashing my phone and follow the steps,when is time to bring out window symbol it off
oluwafemiidowu2018 - Antwoord
cool jais réussir a réinitialiser mon phone
koné gauthier - Antwoord
It works! Thank you very much!
chemiq81 - Antwoord
My lumia phone doesn’t recognize my sim card any more .Guidance please
MASINDE BOB - Antwoord
My Lumia 520 decided to stay offline mode and I can't access the link to boot it
jabulanisithole52 - Antwoord
what means RF inactive?
B N - Antwoord
Yeah it was very helpful. Thank you ?
thomas.osisco - Antwoord
funciono 2022 febrero 23 gracias
rulasromerobug - Antwoord
Yo le hice reset a mi Nokia Lumia 520, pero ya no encuentra las aplicaciones en la tienda de Microsoft, solo sirve para hacer llamadas. ;-)
luisangelveralopez70 - Antwoord
my nokia lumia is telling me to try again in15588 minutes please help
Boy Floyd Ratseane - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 25
Afgelopen 7 dagen: 134
Afgelopen 30 dagen: 618
Altijd: 241,405
