Ga door naar hoofdinhoud
How to Extend A Necklace Chain
Wat je nodig hebt
  1. How to Extend A Necklace Chain, Necklace Chain: stap 1, afbeelding 1 van 1
    • Use nail clippers to cut the links off of your extension chain until it is your desired length.
  2. How to Extend A Necklace Chain: stap 2, afbeelding 1 van 1
    • Remove the links you just cut from the end of the extension chain so you have a chain of your desired length.
  3. How to Extend A Necklace Chain: stap 3, afbeelding 1 van 2 How to Extend A Necklace Chain: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the pliers/tweezers to grip the ends of the last link you removed and pull it open to widen the gap.
  4. How to Extend A Necklace Chain: stap 4, afbeelding 1 van 1
    • Thread the link you just opened wider through your original necklace chain.
  5. How to Extend A Necklace Chain: stap 5, afbeelding 1 van 1
    • With the link attached to the original necklace chain, attach the extension chain to the same link.
  6. How to Extend A Necklace Chain: stap 6, afbeelding 1 van 1
    • Use the pliers/tweezers to pinch the link shut around both chains.
  7. How to Extend A Necklace Chain: stap 7, afbeelding 1 van 1
    • Using the original latch, clip the latch to the extension chain. Your final product should look like a seamless chain!
Conclusie
This necklace is now ready to wear, and the chain can be extended with this method many times!
MaryJane M.
145 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-5, Andersen Winter 2023 Lid van UC Davis, Team 4-5, Andersen Winter 2023
UCD-ANDERSEN-W23S4G5
3 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 637
