Ga door naar hoofdinhoud
How to Dye a Used Shirt
Wat je nodig hebt
  1. How to Dye a Used Shirt, How to Dye a Used Shirt: stap 1, afbeelding 1 van 1
    • The dye used for this guide is Rit DyeMore.
    • Buy the product and make sure to read the instructions on the bottle.
    • Weigh your shirt & follow instructions on the bottle according to weight to determine how much dye is needed.
    • Pre-wash your clothing item and prepare your materials and work area.
  2. How to Dye a Used Shirt: stap 2, afbeelding 1 van 1
    • Add enough water in a stainless steel pot to let the clothing item move freely.
  3. How to Dye a Used Shirt: stap 3, afbeelding 1 van 1
    • Add 1 tsp of dish detergent to the pot.
  4. How to Dye a Used Shirt: stap 4, afbeelding 1 van 1
    • Cover the pot and let the water reach close to boiling temperature ~200 degrees Fahrenheit.
  5. How to Dye a Used Shirt: stap 5, afbeelding 1 van 1
    • Add the desired amount of dye that was measured via the bottle to the water and turn the stove top temperature to simmer.
  6. How to Dye a Used Shirt: stap 6, afbeelding 1 van 2 How to Dye a Used Shirt: stap 6, afbeelding 2 van 2
    • Place wet clothing item in the solution.
    • Stir slowly for 10 minutes.
  7. How to Dye a Used Shirt: stap 7, afbeelding 1 van 2 How to Dye a Used Shirt: stap 7, afbeelding 2 van 2
    • After the desired color is achieved, remove the item from the solution.
    • Rinse the clothing item with warm water.
    • Gradually use cooler water until the water runs clear.
    • Wash the clothing item in warm water.
    • Dry and enjoy your new clothing item!
Conclusie
Enjoy your new wardrobe!
Samantha Scully
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 496
