Ga door naar hoofdinhoud
How to Disconnect an iPad Battery with a Playing Card
Wat je nodig hebt
  1. How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: stap 1, afbeelding 1 van 2 How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: stap 1, afbeelding 2 van 2
    • Line up the left edge of a playing card with the left edge of the battery connector.
    • Use a pen to mark both sides of the screw hole and the end of the battery connector as shown.
  2. How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: stap 2, afbeelding 1 van 2 How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: stap 2, afbeelding 2 van 2
    • Line up the top edge of the card with the top edge of the screw hole.
    • Use a pen to mark the bottom edge of the battery connector.
    • These markings will aid in cutting a slot in the card to clear the screw hole.
  3. How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: stap 3, afbeelding 1 van 2 How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: stap 3, afbeelding 2 van 2
    • The length of the battery blocker is not important, but we recommend it to be about an inch, or the length from the tip of your thumb to its knuckle.
    • Use a pair of scissors to cut out the playing card battery blocker as shown.
  4. How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: stap 4, afbeelding 1 van 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: stap 4, afbeelding 2 van 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: stap 4, afbeelding 3 van 3
    • Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Insert the battery blocker at a 35 degree angle to disconnect the battery.
    • The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Robert Boyd
26.479 Reputatie
94 handleidingen geschreven
Één opmerking
Thanks Robert. Great easy to create tool and excellent explanation.
Kevin Stark - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 251
Altijd: 9,161
