Inleiding
Today we will be doing a deep clean for the Apple AirPods Gen 3 using multiple tricks, and tips I have found and what works for me. Please note in the very unlikely event that you damage your AirPods I, nor iFixit is liable. Also please note this is my first time making a guide so if I did something wrong let me know.
Wat je nodig hebt
Get your microfiber cloth (or any softer cloth) and gently wipe the white surface, and the sensor on the AirPods. You can also put a very little amount of your isopropyl alcohol on the rag
After this very carefully rub the mesh parts of the bud (with a dry part of the cloth) to free-up some of the earwax or dirt
Now grab your spudger and carefully, slowly work your way around that lip where the mesh sits to get or earwax there
Now take your Q-Tip and put it inside the rag, so the rag has a nice point this allowed the cloth to have a strong tip to get inside the mesh
DO NOT USE THE Q-TIP WITHOUT THE CLOTH OVER IT THE COTTON FROM THE TIP WILL GET STUCK IN YOUR AIRPODS MESH
Gently rub around in all directions inside the mesh to get earwax out, you can also use VERY little isopropyl alcohol to help DO AT OWN RISK
A really easy and good trick to see if its all gone is to take your bud and shine a light right in to the grill, and if you see a some shine there is still earwax left.
If there is more left repeat step 3, but please note you will not be able to get it perfect.
Één andere persoon heeft deze handleiding voltooid.
