Inleiding
Darn it! You've got a hole. Not to worry—fixing a hole in a knitted garment is easy. It just requires a needle, some thread, and a bit of patience.
Follow this step-by-step guide for basic instructions on darning. This process can be applied to any knitted garment from socks to sweaters.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Inspect the damage. Clean any dirt or debris from the area.
Tie off any loose threads from the hole.
Pull the needle through to the front of the garment until the thread is taut and the knot catches in the back.
Take a single straight stitch going into a single layer of fabric and coming back up one row of the knit closer to the hole.
Stitch this second row the same way you did the first, but in the opposite direction. This time, go under the rows of knit you previously went over, and vice versa.
When you reach the end of this second row, turn around and continue stitching in the previous direction. Stitch rows back and forth until you have worked about a centimeter past the hole.
18 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
I can and will?!!do this.thank you for presenting instructions so simply and exactly….❤❤video
Thanks for presenting the instructions so beautifully and accurately that I will share in many places………ifixit
We need to find the best option to understand it. I think appliance repair services west Islip NY is the best above all service provider.
Mike fixify - Antwoord
