Ga door naar hoofdinhoud
How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V
Wat je nodig hebt
  1. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V, How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 1, afbeelding 1 van 1
    • Clean the adhesive on the door panel using a wet cloth.
  2. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 2, afbeelding 1 van 1
    • Use a different clean rag and add acetone to clean the area.
  3. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 3, afbeelding 1 van 1
    • Cut out your chosen fabric to size and leave plenty of room for the sides.
  4. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 4, afbeelding 1 van 2 How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 4, afbeelding 2 van 2
    • Spray the entire panel with the adhesive.
    • Spay the adhesive carefully to avoid getting it on an area that you did not want.
  5. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 5, afbeelding 1 van 1
    • Line up the fabric to the panel by starting in the center and pressing down gently.
  6. How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 6, afbeelding 1 van 3 How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 6, afbeelding 2 van 3 How to Cover a Peeling Car Door Panel in a 2002 Honda CR-V: stap 6, afbeelding 3 van 3
    • Use an X-acto knife to push the fabric into the crevices.
    • Keep fingers clear of of the cutting area; blades are extremely sharp.
Conclusie
Your car door panels should now be done. If these is still any peeling of the fabric, you can add more adhesive glue and press down on the panel.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 143
