Ga door naar hoofdinhoud
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: stap 1, afbeelding 1 van 1
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: stap 2, afbeelding 1 van 1
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: stap 3, afbeelding 1 van 2 How to Clear a blocked, or clogged sink: stap 3, afbeelding 2 van 2
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: stap 4, afbeelding 1 van 1
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: stap 5, afbeelding 1 van 1
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: stap 6, afbeelding 1 van 1
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: stap 7, afbeelding 1 van 1
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
Conclusie
Your sink should now be free of obstructions or clogs in the pipes.
4 andere personen hebben deze handleiding voltooid.
Elijah Santiago
196 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 5-1, Prince Fall 2015 Lid van Pasco Hernando, Team 5-1, Prince Fall 2015
PHSC-PRINCE-F15S5G1
1 Lid
1 handleiding geschreven
Één opmerking
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 32
Altijd: 1,711
