Inleiding
It's very easy to clean out a blocked pipe if something is stuck in it. Depending on how your sink is you may not even need tools. This guide will show you how you can easily take care of this issue and unclog, or retrieve what is blocking your pipes.
When you first go to clear your sink, you should check how the pipes are connected.
Your sink should now be free of obstructions or clogs in the pipes.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
