Ga door naar hoofdinhoud
How to Clean the Keurig K75 Platinum Brewing System Needle
Wat je nodig hebt
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: stap 1, afbeelding 1 van 1
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: stap 2, afbeelding 1 van 1
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: stap 3, afbeelding 1 van 1
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
Conclusie
Alexander Vo
94 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-2, Maness Winter 2013 Lid van Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Leden
6 handleidingen geschreven
9 opmerkingen
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - Antwoord
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - Antwoord
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - Antwoord
How about the needle at the bottom of the holder?
tahoejb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 21,917
