Ga door naar hoofdinhoud
How to Clean the InFocus X2 Lamp Housing Screens
Wat je nodig hebt
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: stap 1, afbeelding 1 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: stap 1, afbeelding 2 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: stap 1, afbeelding 3 van 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: stap 2, afbeelding 1 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: stap 2, afbeelding 2 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: stap 2, afbeelding 3 van 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: stap 3, afbeelding 1 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: stap 3, afbeelding 2 van 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: stap 3, afbeelding 3 van 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: stap 4, afbeelding 1 van 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: stap 5, afbeelding 1 van 1
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: stap 6, afbeelding 1 van 2 How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: stap 6, afbeelding 2 van 2
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
Conclusie
Bijgevoegde documenten
Paulina Duarte
553 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 181
