Ga door naar hoofdinhoud
How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel
Wat je nodig hebt
  1. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel, How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 1, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the stickers that are hiding the screws.
    • The sticker may or may not stick back on the mouse after you complete the cleaning. You may want to use some clear tape to replace the stickers.
  2. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 2, afbeelding 1 van 1
    • Remove four screws using a Phillips #0 screwdriver.
  3. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 3, afbeelding 1 van 2 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 3, afbeelding 2 van 2
    • Use a spudger to pry along the center seam of the mouse.
    • Open the outer casing of the mouse.
  4. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 4, afbeelding 1 van 1
    • Remove the wires from the white crimp headers in order to separate the upper and lower housing units of the mouse.
    • Pull the wires as gently as possible to ensure that the wires will not break.
  5. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 5, afbeelding 1 van 2 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: stap 5, afbeelding 2 van 2
    • Take a cotton swab and lightly remove any dirt or debris around the pin connections of the scroll wheel.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Colin
406 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-39, Maness Winter 2014 Lid van Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Leden
16 handleidingen geschreven
1Gids Commentaar
You don’t tell how to put the stickers back because they won’t stick again…
p.pisu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 80
Altijd: 16,169
