Ga door naar hoofdinhoud
How to Clean a Mainstays Coffee Maker Water Tube
Wat je nodig hebt
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: stap 1, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: stap 1, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: stap 1, afbeelding 3 van 3
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: stap 2, afbeelding 1 van 2 How to Clean a Mainstays Coffee Maker Water Tube: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: stap 3, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 3, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 3, afbeelding 3 van 3
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: stap 4, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 4, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 4, afbeelding 3 van 3
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: stap 5, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 5, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 5, afbeelding 3 van 3
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: stap 6, afbeelding 1 van 2 How to Clean a Mainstays Coffee Maker Water Tube: stap 6, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: stap 7, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 7, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 7, afbeelding 3 van 3
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: stap 8, afbeelding 1 van 2 How to Clean a Mainstays Coffee Maker Water Tube: stap 8, afbeelding 2 van 2
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: stap 9, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 9, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 9, afbeelding 3 van 3
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: stap 10, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 10, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 10, afbeelding 3 van 3
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: stap 11, afbeelding 1 van 1
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: stap 12, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 12, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 12, afbeelding 3 van 3
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: stap 13, afbeelding 1 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 13, afbeelding 2 van 3 How to Clean a Mainstays Coffee Maker Water Tube: stap 13, afbeelding 3 van 3
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: stap 14, afbeelding 1 van 1
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
Conclusie
Lorelei Kriss
229 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-9, Andersen Winter 2024 Lid van UC Davis, Team 4-9, Andersen Winter 2024
UCD-ANDERSEN-W24S4G9
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 208
