Ga door naar hoofdinhoud
How to Clean a GE JCBS250DM2WW Glass Oven Door
Wat je nodig hebt
  1. How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 1, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 1, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 1, afbeelding 3 van 3
    • Disconnect the oven from the power supply.
    • To prevent injuries, ensure that the oven is empty and cool.
  2. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 2, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 2, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 2, afbeelding 3 van 3
    • Open the oven door.
    • Use the the 3/32" Allen wrench to remove the two 8mm x 2mm M2 hex screws.
    • When both screws are removed, the door will separate. Make sure to hold it so it doesn't fall.
  3. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 3, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 3, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 3, afbeelding 3 van 3
    • The first glass panel is located on the bottom part as shown in the image.
    • Dip the soft sponge in the soapy water and gently rub the glass until there is no grease or spots.
    • Use a clean cloth to wipe the glass off so there are no streaks.
  4. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 4, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 4, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 4, afbeelding 3 van 3
    • The second glass panel is located on the top.
    • Use the sponge to clean the glass with a soap solution and soft clean cloth to wipe the glass off.
  5. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 5, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 5, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 5, afbeelding 3 van 3
    • For any hard remaining stains, make a paste of baking powder and water.
    • Mix three table spoons of baking power and two table spoons of water.
    • Use the sponge to apply it on the hard stains and let it rest for two minutes.
    • Use a soft cloth to wipe off the paste from the glass.
  6. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 6, afbeelding 1 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 6, afbeelding 2 van 3 How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 6, afbeelding 3 van 3
    • To reassemble the door, press bottom and top part of the door together.
    • Replace the hex screws using the 3/32" Allen wrench.
  7. How to Clean a GE JCBS250DM2WW Glass Oven Door: stap 7, afbeelding 1 van 1
    • The oven door glass is now clean.
    • Be careful when reconnecting the oven to power.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Flying Feather
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 35
Altijd: 195
