Ga door naar hoofdinhoud
How to Clean a Flat Iron
Wat je nodig hebt
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: stap 1, afbeelding 1 van 1
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: stap 2, afbeelding 1 van 2 How to Clean a Flat Iron: stap 2, afbeelding 2 van 2
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: stap 3, afbeelding 1 van 2 How to Clean a Flat Iron: stap 3, afbeelding 2 van 2
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: stap 5, afbeelding 1 van 2 How to Clean a Flat Iron: stap 5, afbeelding 2 van 2
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: stap 6, afbeelding 1 van 2 How to Clean a Flat Iron: stap 6, afbeelding 2 van 2
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: stap 7, afbeelding 1 van 1
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: stap 8, afbeelding 1 van 1
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: stap 9, afbeelding 1 van 1
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
Conclusie
Congratulations your flat iron is buildup free!
3 andere personen hebben deze handleiding voltooid.
Jacquelin
283 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-2, Green Winter 2015 Lid van Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 63
Altijd: 6,584
