Ga door naar hoofdinhoud
How to Clean a Filter on a MAYTAG Laundry Machine
Wat je nodig hebt
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: stap 1, afbeelding 1 van 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: stap 1, afbeelding 2 van 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: stap 1, afbeelding 3 van 3
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: stap 2, afbeelding 1 van 3 How to Clean a Filter on a MAYTAG Laundry Machine: stap 2, afbeelding 2 van 3 How to Clean a Filter on a MAYTAG Laundry Machine: stap 2, afbeelding 3 van 3
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: stap 3, afbeelding 1 van 1
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: stap 4, afbeelding 1 van 3 How to Clean a Filter on a MAYTAG Laundry Machine: stap 4, afbeelding 2 van 3 How to Clean a Filter on a MAYTAG Laundry Machine: stap 4, afbeelding 3 van 3
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: stap 5, afbeelding 1 van 1
    • Screw the filter clockwise back into place.
Eindstreep
Kaelyn Taing
121 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 50-50, Briggs Fall 2022 Lid van CSU Los Angeles, Team 50-50, Briggs Fall 2022
CSULA-BRIGGS-F22S50G50
1 Lid
2 handleidingen geschreven
Één opmerking
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 459
Altijd: 7,204
