Inleiding
Staining a baking sheet makes the item look worn and filthy. Use this guide to clean your kitchenware quickly and easily.
Wat je nodig hebt
Place the dirty baking sheet on a flat surface.
Tip: This method can be used on stained pots and pans as well.
Tip: This method works best if you clean the stained baking sheet as soon as it has cooled after use.
Note: The liquid on the baking sheet is grease. This method will work whether or not there is grease on the baking sheet
Congratulations! You have a baking sheet that looks good as new.
30 andere personen hebben deze handleiding voltooid.
3 opmerkingen
I’ve also had good success getting stains off stainless steel following a similar process but using cream of tartar + vinegar instead of baking soda + water. Cream of tartar with vinegar forms an acidic paste instead of the alkaline paste of the baking soda. Of course, don’t mix these approaches or expect unhelpful frothiness.
Don, thanks for the additional tips, especially the acidic versus alkaline aspects.
is that a non stick baking sheet? How is it on steel?
