Ga door naar hoofdinhoud
How to Clean Nintendo Entertainment System Cartridges
Wat je nodig hebt
  1. How to Clean Nintendo Entertainment System Cartridges, Take Apart the Cartridge: stap 1, afbeelding 1 van 1
    • Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
  2. How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: stap 2, afbeelding 1 van 2 How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: stap 2, afbeelding 2 van 2
    • Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
  3. How to Clean Nintendo Entertainment System Cartridges, Scrub the Contacts: stap 3, afbeelding 1 van 1
    • Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
    • After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
Conclusie
And with that your cartridge should be working properly!
Één andere persoon heeft deze handleiding voltooid.
[deleted]
509 Reputatie
2 handleidingen geschreven
4 opmerkingen
Is this a joke?
Mizuho Chan - Antwoord
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
Randall Mattoon -
In my opinion, a less abrasive metal polish would probably be better to start with.
Jeff Griffith - Antwoord
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
mwbarnhart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 104
Altijd: 2,616
