Inleiding
Hello! In this guide I will show you how to clean NES cartridge contacts. Let's get started!
Wat je nodig hebt
Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
And with that your cartridge should be working properly!
Één andere persoon heeft deze handleiding voltooid.
4 opmerkingen
Is this a joke?
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
In my opinion, a less abrasive metal polish would probably be better to start with.
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
