Ga door naar hoofdinhoud
How to Clean Canon PIXMA MP190 Print Head Nozzle
  1. How to Clean Canon PIXMA MP190 Print Head Nozzle, Turn printer on.: stap 1, afbeelding 1 van 1
    • The printer needs to be on in order to change the ink cartridges.
  2. How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: stap 2, afbeelding 1 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: stap 2, afbeelding 2 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: stap 2, afbeelding 3 van 3
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: stap 3, afbeelding 1 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: stap 3, afbeelding 2 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: stap 3, afbeelding 3 van 3
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
  4. How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: stap 4, afbeelding 1 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: stap 4, afbeelding 2 van 3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: stap 4, afbeelding 3 van 3
    • Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle.
    • Repeat until the nozzle appears free of any ink and debris.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Garret Wescott
597 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-5, Lauer Fall 2014 Lid van Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Leden
5 handleidingen geschreven
Één opmerking
is ther an easy way to gain access to the roller at the rear of the machine to clean it
hope342 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 5,460
