Inleiding
Over time debris can build up on the print head nozzle causing irregular flow resulting in poor print quality.
Onderdelen
Geen onderdelen nodig.
  1. The printer needs to be on in order to change the ink cartridges.
    • The printer needs to be on in order to change the ink cartridges.
  2. To locate the ink cartridges the paper output tray must be in the lowered position. Next lift the scanning unit until the scanning support is vertical. Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Allow the printer to position the ink cartridge carrier into the ink cartridge removal location. Before replacing the ink cartridge ensure the correct ink cartridge is installed. Push down on the front edge of the ink cartridge.
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
  5. Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle. Repeat until the nozzle appears free of any ink and debris. Repeat until the nozzle appears free of any ink and debris.
    • Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle.
    • Repeat until the nozzle appears free of any ink and debris.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Garret Wescott
591 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-5, Lauer Fall 2014 Lid van Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Leden
5 handleidingen geschreven
Één commentaar
is ther an easy way to gain access to the roller at the rear of the machine to clean it
hope342 - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 12
Afgelopen 30 Dagen: 47
Altijd: 2,873
