Ga door naar hoofdinhoud
How to Check Resistance of Suzuki Wagon R Temperature Sensor
Wat je nodig hebt
      • Be careful when working on Engine! Dont test when engine is running. Wait for engine to cool down!!
      Vraag FixBot
      Voeg opmerking toe
    1. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: stap 2, afbeelding 1 van 2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: stap 2, afbeelding 2 van 2
      • Pull the bonnet release handle located on the outboard side of the driver's side of the instrument panel. This will disengage the bonnet lock halfway
      • Push the under-bonnet release lever sideways with your finger. While pushing the lever, lift up the bonnet
      • Continue to lift up the bonnet until it is high enough to support with the prop rod
      • Make sure the bonnet is fully closed and latched before driving. If it is not,it can fly up unexpectedly during driving, obstructing your view and resulting in an accident.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: stap 3, afbeelding 1 van 2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: stap 3, afbeelding 2 van 2
      • The component Intake air temperature sensor is located in the intake pipe just after the Air Filter.
      • Unplug the plug connection by pressing the release tab
      Vraag FixBot
      Voeg opmerking toe
    3. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: stap 4, afbeelding 1 van 3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: stap 4, afbeelding 2 van 3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: stap 4, afbeelding 3 van 3
      • Turn the knob in the multimeter to set the test to Ohms/Resistance
      • Connect the terminal 1 and 2 of the component Intake air temperature sensor to Multimeter positive and negative
      • The set value at ignition on and engine cold is 1.3KOhms
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
ananda
238 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 125
Altijd: 6,564
