Ga door naar hoofdinhoud
How to Change Mortise Lock and its Cylinder
Wat je nodig hebt
  1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: stap 1, afbeelding 1 van 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: stap 1, afbeelding 2 van 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: stap 1, afbeelding 3 van 3
    • Determine the position of the screws on both door handles and the front plate.
  2. How to Change Mortise Lock and its Cylinder: stap 2, afbeelding 1 van 2 How to Change Mortise Lock and its Cylinder: stap 2, afbeelding 2 van 2
    • Use a flathead screwdriver to remove the eight 6 mm screws on both handles.
  3. How to Change Mortise Lock and its Cylinder: stap 3, afbeelding 1 van 3 How to Change Mortise Lock and its Cylinder: stap 3, afbeelding 2 van 3 How to Change Mortise Lock and its Cylinder: stap 3, afbeelding 3 van 3
    • Pull out the door handles on both sides of the door.
  4. How to Change Mortise Lock and its Cylinder: stap 4, afbeelding 1 van 3 How to Change Mortise Lock and its Cylinder: stap 4, afbeelding 2 van 3 How to Change Mortise Lock and its Cylinder: stap 4, afbeelding 3 van 3
    • Pull out the spindle (the rectangular piece of metal) from the door.
  5. How to Change Mortise Lock and its Cylinder: stap 5, afbeelding 1 van 3 How to Change Mortise Lock and its Cylinder: stap 5, afbeelding 2 van 3 How to Change Mortise Lock and its Cylinder: stap 5, afbeelding 3 van 3
    • Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
    • Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
  6. How to Change Mortise Lock and its Cylinder: stap 6, afbeelding 1 van 2 How to Change Mortise Lock and its Cylinder: stap 6, afbeelding 2 van 2
    • Pull the lock cylinder out to either side of the door.
  7. How to Change Mortise Lock and its Cylinder: stap 7, afbeelding 1 van 3 How to Change Mortise Lock and its Cylinder: stap 7, afbeelding 2 van 3 How to Change Mortise Lock and its Cylinder: stap 7, afbeelding 3 van 3
    • Grasp the mortise lock on either side and pull it out from the edge of the door.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hikmat Guliyev
172 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 84
Altijd: 1,843
