Ga door naar hoofdinhoud
How to Change Broken Buttons on your Lexus Keyfob
Wat je nodig hebt
  1. How to Change Broken Buttons on your Lexus Keyfob, Broken Buttons: stap 1, afbeelding 1 van 2 How to Change Broken Buttons on your Lexus Keyfob, Broken Buttons: stap 1, afbeelding 2 van 2
    • Place the keyfob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Keyfob: stap 2, afbeelding 1 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 2, afbeelding 2 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 2, afbeelding 3 van 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Keyfob: stap 3, afbeelding 1 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 3, afbeelding 2 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 3, afbeelding 3 van 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the keyfob.
    • You may feel like you're breaking the keyfob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Keyfob: stap 4, afbeelding 1 van 2 How to Change Broken Buttons on your Lexus Keyfob: stap 4, afbeelding 2 van 2
    • Remove the internal remote to access the buttons.
  5. How to Change Broken Buttons on your Lexus Keyfob: stap 5, afbeelding 1 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 5, afbeelding 2 van 3 How to Change Broken Buttons on your Lexus Keyfob: stap 5, afbeelding 3 van 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
Conclusie
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
6 andere personen hebben deze handleiding voltooid.
Michael Tan
563 Reputatie
3 handleidingen geschreven
Cal Poly, Team 30-3, Green Spring 2015 Lid van Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Leden
9 handleidingen geschreven
Één opmerking
useless guide
Davide - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 103
Altijd: 5,232
