Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Some programs may accidentally run into an inescapable loop, causing your program to become unresponsive. This guide will help you make your calculator responsive again.
  1. To break the calculator out of the loop, simply press the "ON" button. Doing so will force cancel the program.
    • To break the calculator out of the loop, simply press the "ON" button. Doing so will force cancel the program.
  2. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
Conclusie
If the calculator freezes every time you run a certain program, then do not run that program.
John Baek
19 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-52, Forte Fall 2012 Lid van Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 2,962
