Inleiding
Follow this guide to calibrate the in-screen optical fingerprint sensor in your Samsung phone or tablet. You should perform the calibration whenever you replace the screen, to ensure that the fingerprint sensor is accurate and secure.
This calibration procedure currently only works for the Tab S7+'s optical fingerprint sensor. This guide will update as Samsung adds more compatibility. For more information, check out the Samsung Self-Repair document.
You'll need the Samsung fingerprint sensor calibration toolkit in order to complete this procedure.
Download the Self Repair Assistant app here.
Open the "My Files" app.
Navigate to the "Installation files" tab on the left side of the screen.
Select the app on the right side of the screen.
Select "Install" to confirm the app's installation.
Skip the next two steps.
Navigate to the "Downloads" tab on the left side of the screen.
Long press the download file until an orange checkmark appears to the left of it.
Navigate to the bottom of the screen and select the "More" option.
Open the Self Repair Assistant app.
Is not opened
This app fails to open says model not supported
I installed the gpt ap but i dont find samsung repair assistant
Model not supported
Select "Agree" to accept the Terms and Conditions.
App open nhi ho raha hai
In galaxy a31 it doesn't work
Select the "Display" icon.
Select "Continue" at the bottom of the screen.
Select "Start" to begin the fingerprint sensor calibration.
Once the screen turns black, select "Start" again.
Place the white box over the outline near the bottom of the screen.
Cover the outline with the side on the box that matches the pattern.
Where do i get the white box?
Hi there.
Currently, the only way to get the boxes is by purchasing the Galaxy Tab S7+ Screen kit. Samsung intends to sell them separately at some point. This guide is only for the Galaxy Tab S7+ at the moment.
Place the black box over the outline near the bottom of the screen.
Place the side of the small white box with the grooves over the inner portion of the outline near the bottom of the screen.
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
31 andere personen hebben deze handleiding voltooid.
16 opmerkingen
When I open the app after installation I get this toast message "this model is NOT supported"
My device is a Galaxy A71
I have a Galaxy A70. "Fingerprint sensor Calibration needed" when I try to turn on Biometric. *# 0 *# says the sensor is alright (everything pass) But calibration = 1
HOW do I calibrate the sensor? The local samsung service center is trash
When I open the app after installation I get this toast message "this model is NOT supported" My device is a Galaxy A52
Hi there.
Unfortunately, as stated in the introduction, the only device supported right now is the Tab S7+ . Samsung plans to include more devices with time.
It showed not supported for this model... What should i do next
Please my phone does not support and I done have factory reset but still. Please what should I do??
App not supported show how raha h
Hi , is there any app for sm a805f (a80)??
What are these white and black boxes? Any info on them would be greatly appreciated
There are still no more devices than the galaxy s tab..?? I had thought about buying the track gauge.. Does anyone know for sure what devices are supported?
Todavia no hay mas dispositivos que el galaxy s tab..??
Habia pensado en comprar el calibrador de huellas..
Sabe alguien seguro.. que dispositivos cuentan con soporte??
Hi Maribel.
Currently, only the Galaxy Tab S7 is supported for the fingerprint calibration. Samsung is planning to update this in the future.
HOW do I calibrate the sensor? The Local service center is trash
How calibrate for samsung s10+ ? because the apps not support fol model samsung s10+
