Inleiding
Any Spektrum or DSM2/DSMX transmitter can be used with the Nano QX. If you purchased the RTF (ready to fly) model, it should come from the factory already bound to a Blade MLP4DSM transmitter.
Wat je nodig hebt
If using a transmitter other than the Blade MLP4DSM, add a new model to the transmitter.
Select the appropriate model type.
Center all trims on the transmitter.
If using the Blade MLP4DSM, press the trim buttons until you hear a long low beep (roll and pitch trim) or three short low beeps (throttle and yaw trim). This indicates that the trim is centered.
Reconnect the power cable to the battery.
After 5 seconds, the status LED will turn blue and begin flashing rapidly, indicating that it has entered bind mode.
Put the transmitter into bind mode while powering it on.
If using the Blade MLP4DSM, push and hold the left stick while powering on the transmitter. Release the left stick. You will hear a beep and the power LED will blink.
You should now be ready to fly your quadcopter.
